TwinTurbo.NET: Nissan 300ZX forum - Can you explain more on what happens when it "wont idle"?
Polish
on September 04, 2018 at 12:21 PM
TT won't idle at same time as brake, and stop/tail warning
posted by Vert93 (MN)
on September 03, 2018 at 05:18 PM
Will it actually just die when you press the brakes at idle? Or idle roughly? It almost sounds like something could be going on with your brake booster, but not positive.
Vert93 (MN)
17:18:20 09/03/18
Is the 'Gang Point' Ground hookedup at the back of the Penum (n/m)
Cjw3
19:04:28 09/03/18
There are 2 grounds hooked up on the back of the plenum.
Vert93 (MN)
20:57:00 09/03/18
Re: There are 2 grounds hooked up on the back of the plenum.
Metacom
22:38:46 09/04/18
Can you explain more on what happens when it "wont idle"? -
Polish
12:21:55 09/04/18
It will just barely run @ about 550 rpm. And within seconds,
Vert93 (MN)
17:54:57 09/04/18
Re: It will just barely run @ about 550 rpm. And within seconds,
TheKryptKeeper
21:53:34 09/04/18
Sounds like...
GrecV2
06:47:10 09/05/18
Idle is now good. Brake lights come on during acceleration.
Vert93 (MN)
18:31:23 09/15/18
Have you verified that the TPS is set correctly? (n/m)
CarolinaZ_TT
07:09:07 09/06/18
Re: Have you verified that the TPS is set correctly?
Vert93 (MN)
18:33:59 09/15/18
